The remote stopped working - so assumed was the actual controller, changed batteries etc and tried another controller still not working - does this mean the TV sensor has packed up and can this be easily fixed?? grateful for any comment - thanks
many thanks for the replies - the TV functions all work well when using the menu and side switches - problem is not being able to work the tv by remote - the actual controller seems ok as checked, so assume the tv senor has the problem
you can also check your remotes to see if they work with a video camera , camera phone (without taking a picture) , if you hold down a button on the remote you should see the IR L.E.D. on the front of the remote blinking in the camera or video screen..
you would need to find out if the panel with the sensor on is available and also the "crystal and eeprom IC" need to be checked.
does the menu and other functions on the tv work fine ?
