Question about Alcatel Cell Phones
Sim card So I just brought this phone yesterday and put my old contract sim card into the phone? But it says my "Invalid Sim"? Why is that
    New Friend:
    Problem Solver:
  • 8 Answers
Your SimCard off by Customercare contact your simcard customercare
Posted on Jul 19, 2013
6ya staff
SOURCE:
Anonymous
  • 1017 Answers
SOURCE: n73
These are the codes for Network 23430000 T-Mobile-One 2 One;United Kingdom. IMEI 355506016220177 To enter the code to the phone (switch on without SIM card).
Input the Code in the phone as follows:
#pw+??????????????+1#
#pw+??????????????+2#
#pw+??????????????+3#
#pw+??????????????+4#
#pw+??????????????+5#
#pw+??????????????+6#
#pw+??????????????+7#
Here: ?????????????? You should enter generated code.
First code in the end of the string must be added + 1#
Code number 7 in the end of the string must be added + 7#
If you have proper software and You know on which lock, phone
is closed just simply enter proper CODE.
If YOU DONT KNOW – which lock is closed do the following:
1. Enter the first code, if it’s the wrong code – WAIT 30 seconds!!! And then:
2. Enter the code number seven this will open all locks.
How to get ‘p’ ‘w’ ‘+’ signs?
Press
* several times on keyboard of phone...
Your code's are:
#pw+848261673654667+1#
#pw+297915320521512+2#
#pw+923532253127736+3#
#pw+948512273607017+4#
#pw+336226260444320+5#
#pw+182174213033273+6#
#pw+337336163505631+7#
Now a message should appear something like “Sim restriction off”. That means your phone is now unlocked.
!!Warning!!
If the codes don’t work after entering 5 codes You will lock the ‘CODE UNLOCK FUNCTION’ and it will be possible to unlock the phone only by using a cable/device.
Posted on Apr 26, 2008
Anonymous
SOURCE: unlock prepaid pantech c120 to use SIM card from contract phone
That sounds like a feature to me. I suggest you use that to your advantage and put in some prank calls.
Posted on May 26, 2008
budhoyo
UD SETYA ELCOM
  • 26 Answers
SOURCE: Invalid sim
That's cause your phone , you buy bundle with sim card, so provider protect phone to use sim by other provider, or you ever set phones password to use sim, if nothing like that go to service center to solved your problem.
Posted on Nov 01, 2008
Hilton Bristol
  • 567 Answers
SOURCE: i bought an at&t lg neon go phone. i already
Hi there i think your new phone lock, you should buy a New Universal Cell Phone Turbo Sim Card Unlock GSM Card from ebay, it only cost $1.00 and can be use to unlock any cell phone its interesting i think you should try it.
Posted on Jul 12, 2010
xx_paigie_xx
SOURCE: how to fix an invalid sim card
try a different sim card if that doesent work then it might be the phone
Posted on Oct 21, 2010
Invalid sim for Pantech go phone
If the PANTECH says Invalid sim it's locked to network...You need to Unlock it..Specify the network it's locked now,country...Then get the Unlock code
at Mobileunlocksolutions.com/pantech/rs1wp8/ and Unlock it easily..You need to specify the correct Pantech phone model also.
Sep 22, 2012 | Cell Phones
I had lost my phone and went to get a new sim card yesterday to put in my old phone. Today its saying that the sim card is invalid? why is that?
SIM card activation can take up to 24 hours, be patient. If still not working after that period of time, contact your service provider. Thank you, please rate.
Jan 13, 2011 | Cell Phones
I have brought a china mobile CITYCALL U800+ from DUBAI TO MUMBAI now i am facing problem invalid sim,i am a vodafone user
Were you using this handset in Dubai or is this the first time? "Invalid sim" has two main issues, 1. sim lock, 2. sim connector problem.
First, open the battery cover, remove the sim card (if it's inside the battery compartment) and clean the metal contacts of the sim connector using a soft brush or ear bud dipped in alcohol or acetone or spirit. After it's cleaned, let it dry and again reinsert the sim card, install the battery and try again.
If it's been used before, then probably you still have the old sim card, if so install it and try again. If it's ok then borrow a sim card from a friend (for few minutes) or use your old or another available (working) sim card and try again. If both the old sim card and the other (borrowed) sim cards are working without any problem, then there's problem with your vodafone sim card which obstructs it to install on the Handset, perhaps voltage issue, in that case, you better get another replacement from Vodafone.
Or if the old one which you were using works, then your phone is sim locked, try to reset it using the default code 1122 or 3344 or 1234 or 5678 (should be on the manual) [click here for more info about china mobile codes]. To do this, go to settings, select "Restore" and enter the code, proceed forward giving positive inputs "yes" or "Ok".
After it's restarted, try again with all the sim cards.
If all the sim cards show the same error, then the handset might needs to be repaired or need to be replaced.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 03, 2010 | Cell Phones
Nokia 95 8gb china , showing invalid sim or sim
i have a china made mobile n8 but after inserted it shows invalid sim what's the solution of this problem
Apr 17, 2010 | Nokia N95 Cellular Phone
Keep saying insert SIM card
You are trying to use a SIM from another Network or Handset but your phone is LOCKED to your old network and/or to a specific SIM card and number: this is why it is asking you for the unlock code to remove the restriction. It you are no longer under contract or obligations (such as minimum total recharge amounts for apre-paid handsets), then you could try to request the unlock code from the original service provider of your handset.
As for asking to insert SIM card, make sure that the SIM is correctly and securely inserted in your handset SIM holder. Also check that the SIM is still functional by inserting it in another handset: SIM card can be permanently and physically disabled if you attempt to enter too many consecutive invalid codes (usually around 10).
Hope it helps and good luck!
Jan 25, 2010 | Nokia 7260 Cellular Phone
Ithe second sim slot says invalid sim
i think the phone use other provider than your sim card if you put orginal sim card from provider in it the sim card wil be acces
unlocking the phone you can acces all providers
you have contact old provider they wil give you unlock codes after one year for free , you have to give them your imei number you see it under battery or by pressing *#06# and also the old phone number they wil also handel it with email
Oct 28, 2009 | Cell Phones
Sim invalid
it is a problem of network provider,your cellphone is not open to there sim card network provider..
Hope this may help;
DON'T FORGET TO RATE:
Aug 28, 2008 | Nokia N73 Cellular Phone
N80
you must check memory setting,i think you use phone memory change to memorycard use in phone setting at memory status.about sim you must go to shop for more imformation.
Sep 12, 2007 | Nokia N80 Cellular Phone
Cell Phones Logo
269 people viewed this question
Top Alcatel Cell Phones Experts
Tony Pez
Level 1 Expert
Dakshinamurthy...
Ron Rak
Ron Rak
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
