It Means-All the faxes you received now will be placed in memory,The black ink cartridge needs to be replaced.Then the faxes in memory will be printed out.
Thanks for your support
=) SOLUTION!!! To print from memory, simply press the "FAX button on the front panel. Then, press the "MENU" button. "1. Fax Settings" will appear in the display. Press the "right" arrow key once so that you get "Memory Reference" to appear on the screen. Press the "OK" button once. It will display "Print List", but you want to "Print Document", so press the "right" arrow key until you get to "Print Document" and press "OK." Once you are there, press "OK" again and the message "Print 1st page only?" It displays a YES and NO, so hit the left or right arrow key to choose. If you want to print the entire document, choose NO and press "OK" Your document will print out!!! =)
I think I know why. You need to set the proper priority of your all-in-one Canon device. If it is TEL priority, it means you need to have a phone connected to the fax. If the phone rings, you need to pick up the handset and check if it's a fax tone or a call. If it is fax tone, you wait for 5 secs til fax tone stops, and then hang up. After that you will receive the fax. Failure to pick up the handset will not allow you to receive the fax. This might be the most probable setting you have, hence you can't receive the fax. If it is FAX priority, the same thing happens as TEL priority. Only difference is if you don't pick up, and it is a fax, it will still receive. You can also do FAX only. No need to connect a phone. Device will receive automatically.
