When i opened cricket 07 it shows that it has encountered a problem needs to close what should i do?
SOURCE: ea ssports cricket 07
dear friend .
you need to insert the cd for cricket 2007.
(it may be two cd pack)
insert the cd1 then autoplay starts .
and starts installing if it does not start automatically.
double-click on your cd/dvd drive.
after it starts it asks for key which u can get from
crack folder and right click on rid07 aand run as .
it generates the key which then can be used for the installation.
after that it asks for cd2 insert it and finish installing .
for playing u need to copy all files form crack folder.and paste them in your EAgames/cricket07 and replace existing file.them u can play the game.
thanks for reading the solution.
You should change your computer theme. If it still doesn't open, you should run it in compatible mode for win XP.
