I have several flat screen tvs from a business that just closed and all were mounted to walls. I want to use them at home but don't want to mount them on the walls and all of the original boxes and pieces were thrown away. Where can I find a replacement base? Whenever I look on the internet all the sites that come up are for furniture tv stands.
SOURCE: Swivel Base for a 42LC2D
Hi there is normally a set of 4 to 6 screws that hold the base to the tv set that you remove , you can then possibly use the same screws to attach the wall bracket to the back of the tv before mounting on the wall
hope this helps
cheers John
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
SOURCE: how do i take a stand off my lg plasa in order tt
you will see at the back bottom end where your stand goes in there is 2 screws on each side that needs to come off
SOURCE: I am trying to wall mount my LG M197WDP - PZ 19
It's simple!
Step 1: Use a Phillips screwdriver to remove the screws holding the red plate off the bottom.
Step 2: Pop the red plate off (May need some persuasion! It should pop straight out, there is nothing else holding it in place, but be careful)
Step 3: Unscrew the four screws holding the spigot in place, and remove the spigot.
Step 4: Screw the 4 screws bach in place.
Step 5: Screw the red plate back into place.
Step 6: Enjoy!
SOURCE: how do i remove base stand on an lg 50pc65 tv to
you have 3 philips head screws in the base, unscrew this and wil be abel to get it wall mounted after that.
