Van shakes terribly
When does it shake? If it shakes at idle (car is stationary) then it's likely a cylinder misfire. Could be a bad spark plug, ignition coil, O2 sensor... .. If shaking at idle a trip to a shop with a diagnostic tool will tell you where to look. If shaking is under braking it's likely a warped disc brake, if it's shaking at freeway speeds it's likely an out of balance tire. Will need some more info to give you a better answer.
