TO what level of upgrade can I go to on my G5 computer and will an upgrade include the dvd
Leopard requirements/10.5.x...
* Mac computer with an Intel, PowerPC G5, or PowerPC G4 (867MHz or faster) processor
minimum system requirements
* 512MB of memory (I say 1.5GB for PPC at least, 2-3GB minimum for IntelMacs)
* DVD drive for installation
* 9GB of available disk space (I say 30GB at least)
Classic/OS9 Apps no longer supported.
$45.00 on Ebay.com - You can't do Snow Leopard.
SOURCE: mac g5
For a mac, you need to use the grey disk that came with your computer that says Disk one on it. Put it in your computer and turn the computer off. Hold down the N key and turn your computer on. It should ask you to select your language. Select it, then an installer window will come up. Ignore it. Go to the menubar at the top and select Utilities> Password Utility. Select your User account, type in a new password, and click change. you can then restart your computer and log in with your new password.
SOURCE: miniDV to DVD
Do you have Final Cut Pro? If not which editing system do you have. Imovie may do the trick. You need to import the video onto the computer and then process it and export it to DVD via a program that has that capability such as Final Cut Pro or Final Cut Express (I believe that will do it, too).
Hope this helps!
SOURCE: Video ram error 2ATI/1/4:113-A14404-118
This one is pretty clear. Your machine is a June, 2004 model. Your video RAM is bad. Video RAM is not user-replaceable on the Radeon 9800 XT, so you will have to replace the Radeon card itself.
SOURCE: Apple mac G5 freezes when booting up.
Try unplugging all Firewire/USB devices. Also, unplug the power cord from the computer. This resets the logic board. If that doesn't isolate the problem, put your Original system CD that came with the computer and hold down the C key. Boot up and run Disk Utility. Run the repair disk and then repair disk permissions. Reboot and try booting your system again.
SOURCE: power mac g5 automatically shutdown
Check if its not overheating.
Also check your power settings
