Intuit QuickBooks Pro 2007 Full Version (299116) Logo
A
Anonymous Posted on Jul 22, 2013
Error 3371 status code11118
What does it mean
Scott Fair
Level 2:
Champion:
  • Intuit Expert 237 Answers
  • Posted on Dec 23, 2014
Scott Fair
Intuit Expert
Level 2:
Champion:
Answers
237
Questions
0
Helped
99005
Points
281
Look here:
http://support.quickbooks.intuit.com/support/articles/SLN40318
2 Related Answers
QBPOSScott
Scott Fair
  • 237 Answers
  • Posted on Dec 23, 2011
SOURCE: Error code 3371 status code
http://support.quickbooks.intuit.com/support/articles/sln40318
david_willim
jon markan
  • 256 Answers
  • Posted on Jul 31, 2014
Before proceeding, ensure that your copy of Microsoft Windows is up to date.
You may need to re-install your software. Have your license number and product number for your version of QuickBooks ready.
How to locate your license and product numbers
Try these steps in the order shown. If the first one fixes the problem, you do not need to try the other steps.
Fix Microsoft .NET Framework, MSXML, and C++ issues using the QuickBooks Component Repair Tool
Re-create damaged EntitlementDataStore.ecml
Uninstall QuickBooks, download and run the QuickBooks Clean Install Utility, then reinstall QuickBooks
For more help visit
QuickBooks Tech Support
2answers
How to fix QuickBooks Error Code 3371 and status 11118?
QuickBooks Error Code 3371 and status 11118 can occur when there is a problem with the QuickBooks license data or when the data is damaged. To fix this error, you can try the following steps:
  1. Repair or reinstall Microsoft .NET Framework: QuickBooks requires Microsoft .NET Framework to run, and this error can sometimes be caused by a problem with .NET Framework. Try repairing or reinstalling .NET Framework to fix the error.
  2. Repair or reinstall QuickBooks: If repairing or reinstalling .NET Framework does not fix the error, try repairing or reinstalling QuickBooks.
  3. Reset the EntitlementDataStore.ecml file: This file stores your QuickBooks license information, and the error can sometimes be caused by a problem with this file. To reset the file, follow these steps:
  • Close QuickBooks
  • Press the Windows + R keys on your keyboard to open the Run dialog box.
  • Type "C:\ProgramData\Intuit\Entitlement Client\v8" (without quotes) in the Run dialog box and press Enter.
  • Locate the EntitlementDataStore.ecml file and rename it to EntitlementDataStore.old.
  • Reopen QuickBooks and try activating it again.
  1. Contact QuickBooks Support: If none of the above steps fix the error, you may need to contact QuickBooks Support for further assistance. They will be able to help you troubleshoot the issue and find a solution.
I hope this helps! Let me know if you have any other questions
1helpful
6answers
Are Paul Gill and Masonolivia source of Indian spam? Why are their postings below copied from other spam?
When you register or open QuickBooks, you see one of these error messages:
  • Could not initialize license properties. Error 3371: QuickBooks could not load the license data. This may be caused by missing or damaged files.
  • Could not initialize license properties. [Error 3371, Status Code -11118] QuickBooks could not load the license data. This may be caused by missing or damaged files.
  • Could not initialize license properties. [Error: 3371, Status Code -1] QuickBooks could not load the license data. This may be caused by missing or damaged files.
Important: This issue can occur if your product is hosted by Right Networks and you access QuickBooks with WebConnect and then select to open the file without saving. If you use QuickBooks Enterprise and your product is hosted by Right Networks, you must save the file and then import it.
How to fix it:
If the latest Windows updates are not installed, the QuickBooks installation can fail or become damaged. To install the latest updates in Windows, click the Windows Start or Logo button, choose All Programs > Windows Update. Once started be sure to install any updates marked critical.
Try these steps in the order shown. If the first one fixes the problem, you do not need to do the other steps.
  1. Close QuickBooks if it's open.
  2. Open the entitlement data folder for your operating system and version of QuickBooks.
    1. On your keyboard, press Windows + R to open the Run window.
    2. Enter (or copy and paste) the following information, and then press Enter
      • QuickBooks 2014 and Enterprise 14.0: C:\ProgramData\Intuit\Entitlement Client\v8
      • QuickBooks 2013 and Enterprise 13.0: C:\ProgramData\Intuit\Entitlement Client\v8
      • QuickBooks 2012 and Enterprise 12.0: C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2011 and Enterprise 11.0: C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2010 and Enterprise 10.0 : C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2009 and Enterprise 9.0: C:\ProgramData\Intuit\Entitlement Client\v5
      • QuickBooks 2008 and Enterprise 8.0: C:\ProgramData\Intuit\Entitlement Client\v5
      • QuickBooks 2007 and Enterprise 7.0: C:\ProgramData\Intuit\Entitlement Client\v3
  3. Right-click the EntitlementDataStore.ecml file and select Delete.
  4. Click Yes to confirm you want to delete the file.
  5. Open QuickBooks, open your company file, and follow the instructions to register the application.
I get an eror message status Oxc00000e9 what does
There are 3 step to repair oxc00000e9 error
If you got oxc00000e9 error then there is a 94% chance that your computer has registry problems. To repair oxc00000e9 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair oxc00000e9 error.
Here are the url of Perfect Optimizer:http://www.nomoreerror.com/tidpp-oxc0000… Source(s): http://www.nomoreerror.com/tidpp-oxc0000…
No video on my acer aspire 5050-3371
Very hard to solve this... first all, check if you see the image connetting laptop to external video.
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
