Maytag washer I HAVE A MAYTAG WASHER WHEN MY WIFE WASH A LOAD OF CLOTHS, AFTER THE CYCLE FINISHES THE CLOTHS ARE STILL WET, IT DOESN'T RING OUT THE WATER FROM THE CLOTHS COMPLETELY
My clothes are dripping wet when my Maytag Neptune stacked washer is done. I have had a repairman out to work on it three times now; he said someone overloaded the machine and the drum hit a trigger of some kind, which prevents the drum from going into a full spin. This has been fixed once already (the first two visits were from another problem). Since it seems like it's going to be a recurring problem I'd like to know if A) I can get to the switch, B) I can reset the switch myself, C) only a trained repairman can take care of this issue My clothes are dripping wet when my Maytag Neptune stacked washer is done. I have had a repairman out to work on it three times now; he said someone overloaded the machine and the drum hit a trigger of some kind, which prevents the drum from going into a full spin. This has been fixed once already (the first two visits were from another problem). Since it seems like it's going to be a recurring problem I'd like to know if A) I can get to the switch, B) I can reset the switch myself, C) only a trained repairman can take care of this issue
You can't post conmments that contain an email address.
Check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
ceck for kinks in the drain hose .if you have a wet vacuum try sucking on the drain hose, or fallow the drain hose into the back of the unit to see if there is a blockage or a belt off .. jay florida
