Need drivers for Linksys Wireless-G WUSB54GC Xp-sp2 driver v1.4 usb wireless adapter
Hi.
Linksys Wireless-G WUSB54GC Xp-sp2 v1.4 usb wireless adapter driver (xp sp1/2/3 + vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Http://downloads.linksysbycisco.com/downloads/WUSB54GC_20051
Go to the link below to get the most recent driver for Linksys WUSB54GC for versions 1 and 3. The site is a collaboration site that I have started to support Linksys Wireless products, especially ones with Ralink chipsets. If your wireless adapter is silver and Model No. is "WUS54GC" then it is version 1. If your wireless adapter is black and Model No. is "WUSB54GC ver.3" then is is version 3. The drivers were built form the most recent Ralink driver packages. Ralink is the chipset manufacturer of these wireless adapters...
http://sites.google.com/site/linksysupdateddrivers/
http://www.linksysbycisco.com/US/en/support/WUSB54GC/download and select thr version of the adapter (must be 1.0).Now scroll down.On left side you can see dowload drivers
Go to the following page to select your settings and get the correct drivers:
http://homesupport.cisco.com/en-us/wireless/lbc/WUSB54GC
be sure to Rate/Vote
Follow the links - http://www.linksysbycisco.com/US/en/support/WUSB54GC/download
select version 3.0( updated drivers)
that will work for all versions . ypu will driver in left bottom corner
SOURCE: I tried to access my
You have to connect to your network without using wireless then u have to go to the linksys website and download the windows 7 driver. Install that driver then u can connect with wireless. Worked for me! Gl.
SOURCE: WUSB54GC cannot associate with access point
Hi ian90,
Since u r using a linksys products no need to worry..it will work..
In the right bottom corner of ur computerscreen u can see a green square box(linksys
wireless icon) right click on to the green box and click on "use windows Zero
configuration" after clicking on to that u can see a small computer with wireless waves in the right bottom corner,right click on to it click on connect to a wireless network..u can see ur SSId click to connect it...it will prompt for a network key..enter the key and confirm the key..it will connect for sure..hope it will work..if there is any issue just revert back as soon as possible..
SOURCE: unable to setup Linksys WUSB54GC wireless network adapter
The Linksys WUSB54GC isn't compatible with Windows Me, upgrade to XP or Vista.
Minimum Requirements
