How can I fix this?
Hello. There is an LE error that means "fill error". There is also a "tE" error that means "sump thermistor failure". You are probably getting the tE error--the thermistor is located at the bottom front of the washer tub in the center. If water is leaking from the bellow(the rubber part that seals tightly against the door), it might be spilling down onto the thermistor wires, shorting it out. With any leak, this will be an INVOLVED repair. My suggestion is to call for service--to reach anything in the front of the washer internally, the front panel must be removed--this is complex, and must be done carefully, especially if the bellow is leaking and needs to be replaced. I hope I helped you!
