SOURCE: everytime i turn on my
Link
phandroid.com/2008/10/25/how-to-reset-your-g1-and-start-from-scratch
"It
came time to part with my review unit of the G1 (Thanks T-Mobile!) and
send the phone back to its rightful owner. But what about all the
personal info on the phone? The apps, texts, e-mails, AIMs and all that
jazz? A quick search of AndroidForums.com turned up an easy way of
restoring your G1 to factory settings:
if you power
off your phone and hold the home (shaped like a house) and the end (red
hangup button) for about 20 seconds you get a triangle with an
exclamation point and a picture of the G1.
Now all
you have to do is pop open that pretty QWERTY keyboard and there are
several keyboard shortcuts you can use to accomplish what you want to
do:
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
thee last option (Alt + W) and restored my borrowed G1 to factory
settings. I'm sure the soft reboot could be helpful too, should you run
into problems a troubled application may have caused. We didn't try the
other 2 options so use at your own risk.
By the way, I couldn't
live without a G1 so I made the leap and purcahsed a G1 with a T-Mobile
service plan. I'm still a loyal Verizon customer and will simply have to
keep both plans... but I NEEDED the G1. So basically, you can expect the
application reviews and insight you've gotten at phandroid.com to
cotinue since we've got our very own device now!
[Via Android Forums]
SOURCE: my pandigital keep makeing me forceclose evrythingand i cant do nothing
It may the processor problem. or reinstall it and see.
Another method is to contact the supplier for help if you could not fix it.
Android 4.0 Tablet PC
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
