Giving it a shot, hold on. Opening on bottom that goes between fridge and freezer always open its just a hole there. Took this acid panel off and coils are frozen. I think its the temp control, I changed it and I don't remember what its suppose to be set on
check the damper door located between the freezer and refrigerator compartments(this lets in the cold air from the freezer) and make sure it opens and closes with your temp adjustment in the refrigerator compartment,sometimes they ice-up and are frozen in one position then take a hair dryer and defrost the door
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through it.
Make sure this fan is running. You may have to hold the door switch in for it
to run. There is a flap you adjust with
the fridge temp. control. Make sure it's opening and closing when you adjust
the fridge temp. The problem could be the electronic control if
you have one or the mechanical linkages.
Sounds like the evap. fan motor is not turning. What is the freezer temp. have you measured it ? What about the fresh food section, (fridge compartment).
Anyway, try this. Hold the door switch in the closed position with the freezer door ajar and see/listen for the fan coming on. If you can't be sure, the best way to do this is to first turn the thermostat all the way to the "off" postion, and with the freezer door ajar and holding the door sw. closed (pushed in). turn the thermostat back on. (you may need to turn off then back on first if your arms aren't long enough) You should hear the fan motor start.
NOTE; you may hear the compressor overload "click" off if trying to start it right after shutting down, this is normal (under short cycles or manual restarts). You may also hear the condensor fan motor run (under the fridge by compressor) this too is normal. try to indentify the freezer fan (evaporater fan motor) running or not.
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
frozen coils not always means freon problem. low air flow across evaporator coils could cause freeze up. if door is opened and closed an abnormal amount could cause a freeze up or even something pushed up against the air intake in the refridgerator. i would thaw it out completely and restart it, theres a chance it was nothing major. good luck
You'll need to tear into it to answer these questions. I suspect the defrost cycle isn't working or the fan is broken. The best way to see what's going on is to take everything out the freezer drawer and remove it. Then take the back panel off the interior rear wall of the freezer section to expose the coils. The coils should have a very even white frost pattern on them (not frozen solid anywhere). If they are frozen up then the air can't flow around them to cool the fridge properly. If the coils seem "normal" with frost only then is the fan just above them working? That fan circulates cold air to both fridge and freezer sections. Let me know what you find out in order to lead you to a repair part.
thanks I will, anything in particular I should look for?
a good amount, not a whole lot
