NSIC (National Small Industries Corporation) is a government enterprise under the supervision of Ministry of micro, small and medium enterprises (MSME). It has been constituted to promote and help the MSME industry by proposing many schemes such as single point registration of government purchase, marketing support and more. It helps MSME business players to grow their business and market effectively. https://www.gsbtaxation.com/in/nsic-registration-consultants-in-delhi
1.The router does not ship with a password, so just click Submit.
2.And if it doesn't work then try this click on login enter username: MiniAP password: Admin 3.If suppose the above also dint work then renter username: Admin password: Admin
You can log into the router by putting this in your browser http://192.168.1.1/ , then the user and password is normally admin - admin. or admin and password is password. You may also google the brand and get instructions from the manufacturer's forum. Once in the router, you can get the WEP code.
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 -
now you are in service mode, - stop 0 C, and there shold be admin pwd
You need to be in the ADMIN. to change / enter codes. There is a separate code for the ADMIN. Input that code and you can change, edit, add new codes. If the ADMIN code was not ever changed then it will be the default code in the manual. Be ready because the code is not where you think in the manual. I believe it is is the setting section or check management settings. The default is usually 000000 or 111111.
You need to have the ADMIN code to access, change, edit, delete or install new codes. Look in the Management setting under user tools. Look for user codes or key operator codes. Defualt ADMIN code is normally 000000 or 11111, that is if the ADMIN code was not changed.
