I just changed the tube on my bike tire how do I get the rear wheel back on?
SOURCE: removal of sprocket and gears from rear tire for replacement
A special sprocket removal tool is required usually only $20 to $30 bucks at a decent bike shop.
SOURCE: back tire changing on mongoose gravity games bike
If you have pegs on the back you will need a deep socket to fit the nut and a socket extender and a socket wrench. with the wheel off it is just the same as changing any other bike tire. Just make sure you check the inside of the tire carefully for anything poking through that may puncture your new tube. Also check to see if you need a new tire and make sure you inflate the repaired tire to the correct pressure or you may get a pinch flat.
SOURCE: new mongoose 20'' bmx. trying to adjust the brakes???
undew the screew at the back of the breakes and turn them round slightly so the wheel in midlde then tighten back up should stay in midle then just not put on straight thats all mate
SOURCE: New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
SOURCE: Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
