Shaver battery is fine, it charges but doesn't turn on. It displays a red light constantly, no flashing. I've tried the 3-5 seconds holding down the button to see if it has a travel lock feature, Didn't work. I've take it apart and took the motor out, red light stays on still, attached another motor, red light still and doesn't power on. I know the battery is good as it has been a red light for 3 days and when I plug it in to charge, it glows green to state it is charging.
SOURCE: My shaver doesn't stay charged very long
The motor is fine, what happens is that the internal battery loses the ability to fully charge and run the motor for a long period of time. While you "could" change the battery out with a newer one using solder, it's unlikely that it would cost less than buying a newer model at the store or from ebay. The average life of good shavers made a few years ago was about 3-5 years due to the type of batteries in it. I used mine with a charging cord for a while but that became an issue once while traveling. I bought a new one.
SOURCE: red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
SOURCE: Norelco shaver 6866XL won't charge, light glowsred
The battery is probably one with multiple cells and one (or more) of them has shorted preventing the total from reaching a voltage that appears as fully charged.
If the cells are Ni-Cads, this is a common problem with them and when a battery-operated item of mine fails, I replace those older types with NiMH cells if the battery compartment can accept them.
I have 'restored' countless NiCads over the years by 'zapping' them with a fairly high current for a second or two; voltage isn't important as long as it is in excess of 2-3 volts but the source should have a few amps capacity.
This type of cell grows 'whiskers' that will cause them to short completely or develop a path that causes them to self-discharge faster than normal.
SOURCE: I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
SOURCE: Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
"s pass status check the passport number" what does that mean?
