Apparently this particular printer is no longer on the market. The 1270 is listed and appears to be the same printer except it's white instead of black. The cartridges listed for that printer arelexmark 16, 17, 26, or 27.
make sure the usb cable is properly connected and the driver is installed. Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd. Make sure you install the driver properly and check the test print also .still if u fail check all this setting and follow this steps,1st you install the driver disc which is come along with the printer and when the software prompt you to connect the cable then plug the usb cable and follow the instruction. Have a nice day and do not forget to rate please...!
click on above link and download driver then install in computer then your printer works fine. Let me know if you need further assistance. Thanks for using FixYa.
If you do not have the disk you must download the software from Internet, follow instructions below, Click here:OfficialLexmarkDriversand Software
A web page will open, follow instructions, select model, select operative system etc., and click on download . Chose to download the file in my documents when asked. After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
Unplug printer USB.
Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
Download driver from website, or use the diskand runthe install file.
Follow driver installation wizard.
Plug back printer when prompted from installation wizard.
For the Lexmark 1270, go to www.lexmark.com and click on DRIVERS AND DOWNLOADS. Then use the DRIVER FINDER. In SEARCH BY MODEL, type in 1270 and you can choose a driver from there.
That is because you connected the printer to usb before installing the software. Ensure that the account that you are using has administrator privileges( it is not limited). Do a system restore to one week ago see here:
How to perform System Restore on Windows...
Then do the following.
Unplug printer USB.
Go to control panel >> installed printers in Windows and remove (delete ) your printer from printer list.
Use printer disk to install driver or download and run driver from website.
