Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
Posted on Apr 01, 2009
Thermal fuse on sony KDF-60XS955
Can anyone tell me where i can find a picture of the thermal fuse on a sony KDF-60XS955 tv and also where to purchase one thank you in advance!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
975
Points
Check out link below for part. i have 55cs955 and just ordered one. I still do not know where to find in TV but as most post says its somewhere near lamp housing.
http://www.partstore.com/Part/Sony/Sony/191002393/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KDF55XS955
Tv will come on but shuts itself back off
Sounds like it just needs a new lamp.
The way to tell is the lights in front:
green blinking as TV reboots = bad lamp
red three blinks = door switch
red four blinks = bad fan
6 or 9 blinks = bad thermal fuse
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
1helpful
2answers
6 blinking red lights
You still have your guessed problem. 6 blinks means Low B+ error (power supply). This can be caused by an open thermal fuse, loading by another circuit board, or the power supply itself.
3helpful
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Where do i purchase a thermal fuse ?
I ordered my thermal fuse from partstore.com 1-866-925-7278 part number 191002393 My tv model number is kdf55xs955 I understand they are the same fuse I did not receive it yet but I am sure hoping this will solve my problem. I will let you know.
Please help-question about sony optical blocks
Talk to Sony about the blue blob issue, they may still replace the optical block for free.
If not, fix the blinking light TV.
Blink Codes
3X - Lamp cover not installed correctly, usually after lamp change, or cover detect switch is bad.
4X - Check fans (one or more failed to pass RPM test during power on diagnostics)
5X - Lamp ballast (power supply)
6X - Usually the thermal fuse - usually from inadequate air flow (fans dusty)
All other codes usually require a trained technician to diagnose and repair.
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
2helpful
Sony kdf-60xs955, rear projection tv
There is a Thermal fuse under the lamp housing that opens up and Sony has a New style fuse to replace it with, it opens up one of the p/s lines to set code 6, replace with new thermal fuse and test. You will want a Skilled Professional to replace this fuse as it does require some dissassembly and removal of light engine to remove fuse from under lamp housing to put new one on side of lamp housing.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
