I Had an E error (not an E1 error) when I was fiddling with my humidity/temp sensor on the face of the radiator fins (behind air filter). The sensor was WET. I dabbed it dry, let it sit all day, and re-assembled. It works fine now.
If the air conditioner works and is blowing out super chilled air, then the dehumidifier function should work. The function takes in warm moist air and passes it over plates which are marginally colder than the ambient air. The air condenses and drips into a collection tank, or some have drain hose for putting into a floor drain.
After 8 years, it may need service and gassing up, but you may also have drier air than you think. Whether is works in AC Mode is the key.
Your model Delonghi Dehumidifier has been retired. Therefore, no online manual is available. However, if you contact Delonghi Customer Support (1-800-322-3848), they can furnish one and answer the question about the PF error code at the same time.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
should actually be E1 error.
