Microsoft Visual Basic 6.0 for PC Logo
Posted on Apr 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting database to vb
What should i do..plzzzz help..me im a begginers and i dont know how...can i use dezign for a graphical?
Anonymous
Level 3:
  • Master 555 Answers
  • Posted on Jun 15, 2009
Anonymous
Master
Level 3:
Answers
555
Questions
0
Helped
226710
Points
1636
What database you are using?
1helpful
2answers
I dont know the disadvantages of visual basic.
visual basic, is only a basic programming language, most programs will run on Java script, microsoft is visual basic though, but it uses a lot more complex scripts then, if you like the programing language, go for it, but i did not like it.
Also
VB is undoubtedly the simplest and easiest platform to build major Windows applications. The problem is that like other Microsoft products they change faster than I change my socks.You will certainly need more than just VB. Get into server and client side scripting and the use of VB Net.
1helpful
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
I cant make mde file of my database
From the modules object I selected debug menu and from there chosen compile option.
The problem was solved within a second.
Retrieving acess data which is password protected thru VB
You will need to use a connection string. But - before you can configure the string correctly, I'd need to know how the data is stored (Access, SQL, ODBC, etc). You can find examples online. Just know that you are looking for "Connection String." Here's two examples:
1. For MS Access (Jet files):
' Set up the connection string.
m_strConn = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & strDestDBPath & ";" & _
"Jet OLEDB:Engine Type=5" ' NOTE: Use Type=5 for Jet 4.x.
2. For SQL database:
g_strADOConn = "Provider=SQLOLEDB;" & _
"Data Source=SERVER_NAME;" & _
"Initial Catalog=DATABASE_NAME;" & _
"User ID=mssql_userid;" & _
"Password=mssql_password;"
Sir,How to write the code in visual basic to create database in oracle? please help me.
Hi
I guess when you say database thats what you mean and not schema . the terms of database and schema are different from one db to another .
Usually you don't create database from vb or other language, although i guess you can do that .
follow the commnds in the folowing link you just have to embed them in your vb code .
good luck
1helpful
Sir how to set a messagebox in vb.net
To display a MessageBox:
MessageBox.Show("This is your messahe text!", "Title of Your MessageBox", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
Regarding connecting to an Oracle database, you'd have to search for the connection string.
Database connectivity
Please follow the link below to help with connecting to a database and displaying data using visual basic.
http://www.freevbcode.com/ShowCode.Asp?ID=1257
Please let me know if you have any questions.
Thank You, Raph30
Insufficient memory
Check you disk space. [my computer] right click on Local Disk C. im a begginer myself, so i dont know much, and i cant help you a lot.
Vb database connectivity
use odbc tool located in controll pannel and make a database file for use from visual basic6.0
Executing VB application from shared drive
I donot have much expertise on the subject but I think you can do the same by connecting your Database through ODBC connectivity than direct connection. In that way your database will be only on one Server and all can use the same by just using the program from their own console.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
