Is your phone locked to a GSM network? If yes,then most of the GSM phone can be unlocked using unlock codes. But,Apple iPhones can be unlocked remotely using remote unlock service. You can get unlock codes for Blackberry mobiles for cheap from unBBlock.com . To unlock other GSM phones visit SimpleUnlocking.com . They provide unlock services for almost all GSM phones.
SOURCE: Reply!
hi! Get unlock code from here:
www.instant-unlock.co.uk/acatalog/NEC_Unlock.html - 23k -
or
www.foneszone.co.uk/unlock_info/NEC.php - 422k -
or
www.unlockitnow.com/NEC/ - 60k -
SOURCE: lock with optus network.pls need to unlock
Hello,the truth is that you can unlock the phone ,but you can't unlock all phone for free.The payment sites are very cheap you could try it out and see.You can the link below to unlock .
Note: unlock is not free, You will be charged to get your unlock code.
The only way by which you can get the unlock code for free is by calling your service provider and requesting for your unlock code.
If you service provider refuses to give it to you, then there is no other place where you can get a free unlock code.
When you click on wrong pins, and you forget your pin number, the phone will get to a lock mode..
Trying to unlock it manually will not be possible at that time,because your cell phone will be unacceptable..
At this point in time, you will need to unlock the phone..
There are two methods in unlocking the cell phone..
!. Going to a local cell phone repair store around your area..They will help you unlock it..But it will cost you some money to unlock..
!.Also Through the internet. There are some links on the internet..Allyou will need to do is to give your phones IME..number, make and the model of the cell phone...
Below are some links you can use to unlock the cell phone..
Visit the links below if you are interested in buying the unlock code:
(hubpages.com/tag/cell+phone+unlocking/hot)
and
(mobileunlocked.com/mobile_unlocking.php)
http://www.unlocker.com.au/
http://www.mrunlock.com/
http://www.askstudent.com/hacking/how-to-unlock-a-cell-phone-for-free-and-get-unlock-codes/
Hope it helped..
SOURCE: hi i buy cellphone to
first check MEP try . if your MEP is 0 Left . cable process can unlock your Blackberry Bold 9700. after that your Blackberry will unlock . and no need your Network unlock code. go local mobile repair shop. and done this process.thanks
