Question about Sunfire True Sub MK II Subwoofer
Sunfire annoying popping noises
Every now and then my sunfire issues 3 to 5 loud pops. I can't pin down any input sequences that produce the popping so I can't re-create the noises. It started about a year ago and seems to be getting worse.
  • Vorsche Apr 01, 2009
    Mine does the same thing, I took it to a very good local shop and they told me one of the subs was over extending the coil. I need to send it into the repair facility, if I can get them to call me back.
If you remove the volume knob, and tighten the nut below, it should take care of the popping noise, as well as any input noise issues. Based on my experiences with my MKII
Posted on Jul 08, 2009
  • under2x Oct 12, 2010
    This totally cured my intermittent hum on my mk 2... was driving me insane. I tried an adapter to isolate the ground (thinking it was a ground hum) and even a ground isolating power conditioner. Nothing worked until I saw this and tightened the nut under the volume knob.
    New Friend:
There are grounding issues on the Sunfire subs, your best bet is to solder a ground network connecting the negative side of the RCA inputs, and potentiometers to ensure the are connected directly to the ground-lug (green wire) inside the amp. Make sure it is disconnected from the power for a few days before you open it, or the 200volt capacitors could give you a hit!
Posted on Sep 15, 2015
6ya staff
SOURCE:
Bose Companion 3 Speakers make a popping noise.
No solution i'm afraid. But i have the exact same problem. Terrible cracking interference. Unplug everything else in the house and they still crackle. Very annoying. Decided to buy a new woofer on ebay as that seemed to be the problem with possible faulty switch, but the new woofer has a different connection for the volume control. Incredibly frustrating. If you have any luck let me know. Bose want eighty quid to repair...
Jan 31, 2013 | Bose Companion 3 Computer Speakers
Westinghouse TV making crackling sound
I have had the same issue with a Westinghouse 50 inch LED TV. I believe it is not the power supply but the HDMI input. You can temporarily work around by plugging your primary source into the other HDMI. You may also get some relief by using the Westy remote, finding the TV menu, then selecting (Option) (Restore All). There may be an arcane procedure to reset the HDMI.
Jan 01, 2013 | Westinghouse Televison & Video
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
Every time i put on my breaks, there is a really loud popping sound. really loud. i have a 2001 sunfire. help me please.
Hi Megan,
I appreciate you adding me to your list of contacts and asking me to help you with your problem.
However, I don't know if I can be much help from here. Noises can be very difficult to diagnose when you actually have the vehicle in front of you. All I can tell you for sure is that the noise you are hearing is not normal and if it happens only when you apply the brakes, then it is most definately brake-related. I have had some vehicles making noised as you described because of broken brake hardware. I have had some with similar customer complaints that have had loose or missing caliper mounting pins. Then I have had some that the problem was not the brakes at all, but rather lower control arm bushings that were coming apart and applying the brake was making the entire front suspension shift and make a loud popping noise.
My professional advice is to take it by a professional auto repair shop and have one of the technicians drive the vehicle. They may be able to give you some idea of what is going on just by hearing and/or "feeling" the noise themseves. Then again, they may tell you that the wheels need to be removed for a full brake and suspension inspection before they can tell you anything.
I wish I had a more "cut-and-dry" answer for you, but I am afraid that is pretty much impossible at this point.
Good luck,
Dave (dttech)
Dec 05, 2011 | 2001 Pontiac Sunfire
Everytime i use the brakes on my 2000 sunfire i here a loud knocking noise in the rear.
you probably have a shoe that has become dislodged from it's anchor point, you need to remove the wheels and pop the drums off to visually inspect the brakes.
Dec 23, 2010 | 2000 Pontiac Sunfire
Sunfire Subwoofer 110 Noise on input plugin
A few more questions-
Does the sub hum without anything plugged into it except for power? If it makes a real loud hum almost a squeal then I think the rca cable between the receiver and the sub is dead shorted and needs to be replaced. If it's more of a low level hum, then it's a ground hum caused by many things, ie........the receiver and the sub being on different power circuits in the house.......sometimes diconnecting the cable tv feed as it enters the room while the sub is connected and humming to see if it stops........the easy fix sometimes is using a 3 to 2 prong ac adapter but lifting the ground on such a powerful amp could be a fire hazard.
Sep 25, 2008 | Sunfire True Sub MK II Subwoofer
Sunfire Mk II hum (different from greekboy post)
I had this issue a few years ago and the power cable from one of the inner terminals had come loose. It was still touching but whenever the sub would really pound it would jump off the connection and then reconnect causing it to hum. It was the most annoying thing ever so I finally pulled off the amp plate (super easy) and you could clearly see the loose wire. I had to use a good soldering iron to put it back on since it's a pretty fat wire. If you're not under warranty anymore then pop the back off and see if that's the issue.
-Dylan
Aug 17, 2008 | Sunfire True Sub MK II Subwoofer
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Sunfire True Sub MK II Subwoofer Logo
1,646 people viewed this question
Top Sunfire Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
