Samsung Galaxy Tab 101 Tablet GTP7510MAyXAR Logo
Anonymous Posted on Jul 30, 2013
The sceen isn't showing anything. It was just working and now its not showing a display or charging.
Anonymous
Level 1:
New Friend:
  • Contributor 9 Answers
  • Posted on Jul 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
9
Questions
0
Helped
1371
Points
48
Try turning off the device and then turning it back on and listen to those sounds that it makes. if it does make any sound, gotta be a problem with the display.
Can some one help me my step son was playing with his iRULU tablet while it was charging and it has gone black and when you turn it on you can hear it and you just can't see it what can I do to fix it
Shine a flashlight on the display while it is running (I assume a game, anything is ok) if you can faintly see the display working then the backlight has failed on the display.
Otherwise - try resetting it, removing the battery(if you can) and then giving it a full charge.
Goodlucj
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
Huawei s7-931u not power
Use a pin and press the reset hole on the back of the tablet.
If that doesnt work:-
Check your charger it may not be working - plug into a usb socket and let it charge from the computer.
My tesoar tablet showed charging for 3 seconds then that was it now it wont turn on it wont do anything
I have a hacker inside my Samsung galaxy 8 notebook, he controls my ph and I pad, how do I break the tracking link.
2answers
Trying to connect laptop to 46 in sony bravia, will show desktop but will not show the internet or anything else. please help
When you have the laptop connected to the telivision are you running both displays? In other words is the screen on for the laptop and the telivision at the same time? Sometimes if both displays are on you cannot run programs on both. When you use the FN key and press the display button(usually F5) it should cycle thru each time you press it. Try pressing it until you only have the display showing on the televison only. Doing this should make the telivision the main display.
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
