Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Are attachments for a KitchenAid K5 compatible with the K55?
Are attachments for a KitchenAid K5 stand mixer compatible with the K55? In particular the Hobart KitchenAid Grain Mill.
    Novelist:
  • KitchenAid Expert
  • 185 Answers
That would be incorrect. If the attachment is for a hobart kitchenaid mixer then it will fit all models of kitchenaid mixers including the brand new pro series because the attachment port and drive gear has not been changes since 1925 or 6 when it was first introduce by the Hobart company.
Posted on Sep 21, 2012
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
All attachments made by KitchenAid or even back to KitchenAid made by Hobart will fit into the attachment hub on the top of your mixer, This dates back to about the 1920's. They will fit and work on your mixer.
The older grain mill attachments made by Hobart are fantastic and hard to find. But thanks to KitchenAid any attachment (except the icecream maker) are universal to ALL models of KitchenAid mixers.
Posted on Apr 23, 2015
  • 145 Answers
Kitchenaid stand mixer attachments are considered universal, which means compatible with all mixers. However, all Hobart attachments pre-date the new motors of Kitchenaid and would not be compatible with Kitchenaid mixers.
Posted on Jul 08, 2009
6ya staff
SOURCE:
What model kitchenaid was made in december of 1973?
Is the brushed band around the head missing or worn off? The model is on that band. If it worn or missing in order to correctly answer your question I need more information. Is your mixer a tilt head or a bowl lift variety? Did you look on the bottom of the base for a serial number? Some models had them there. Can you describe the ceramic piece a little better? Many models shard the same internal parts and it might not be too difficult to locate that part.
Aug 03, 2014 | KitchenAid K45SS Classic Stand Mixer
How do I fix a k5-a kitchenaid stand mixer?
Depends what is wrong? they are actually very simple and parts are cheap.
Jun 23, 2014 | KitchenAid K5SS Heavy Duty Commercial...
How torepair stand mixer kitchenaid model K5-8
KitchenAid might be able to supply repair instructions.
May 10, 2014 | KitchenAid Food Mixers
I want disassembling procedures
How do I remove the housing on a vintage kitchenaid mixer k5-A
Oct 23, 2012 | KitchenAid K5SS Heavy Duty Commercial...
My wife has a K5A mixer from the '70's that she loves. While I was checking the brushes, I over-tightened the brush cap and broke the threaded part it screws into. Can I get a new part?
The Brush holder caps / covers for the K5 series whether Hobart or Kitchenaid by Whirlpool (after 1986 when Whirlpool bought Kitchenaid from Hobart) will fit the K5-A they just wont be flush like the older Hobart caps. They come in black or white.
Jan 10, 2012 | KitchenAid K5SS Heavy Duty Commercial...
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Oil leaking, sounds like the problems folks are having with the K55 model
Could you please describe the issue in more detail? Thanks.
In the meantime, I will see if I can locate a service manual.
May 23, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid 575 Professional Mixer
Read the instruction manual. There is a screw to adjust the beater height, it is where the mixer joins to the stand.
Feb 28, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
1,610 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
