COLOR REG. IS OFF. WHEN YOU GO INTO MENU AND AJUST YOU GET A MESSAGE ''FAILED''.COLOR CALIBRATION OK. JUST REPLACED BLACK DV UNIT
I would actually start with the cleaning unit right below the transfer belt. If it's worn out, it often streaks colors even after you've replaced the PCUs. As for the Calibration failure, I would make sure the chrome like roller underneath the transfer belt is clean. The sensors look through the transfer belt and reflect off this roller.
It sounds like the transfer belt needs to be replaced. They get scratched up and milky looking and the sensors can't see the color reg marks good enough. It could be other things also but the transfer is a good place to start.
Testimonial: "thanks fo your help ALBERT"
THANKS FOR YOUR HELP. ALBERT
