Just moved my plasma tv and when turned it back on its now got 2 black lines down the middle of it..does any1 know if this is an expensive problem to fix ?
I owned plasma tv about 2 years and half and now I have black line in the middle? I need to fix it but not sure how much it going to cost me? If any know know where to fix them cheaper please let me know.
Thanks I owned plasma tv about 2 years and half and now I have black line in the middle? I need to fix it but not sure how much it going to cost me? If any know know where to fix them cheaper please let me know.
Thanks
black lines on my plasma tv and I don't think that it can be fixed? Better buy new one throw the bad one away.black lines on my plasma tv and I don't think that it can be fixed? Better buy new one throw the bad one away.
AnonymousJan 06, 2008
Had my Zenith Plasma for 3 years and now have the "black line of death" down the center of my screen.
Does anyone know if it is cost effective to have it fixed or should I just buy a new one.Had my Zenith Plasma for 3 years and now have the "black line of death" down the center of my screen.
You can't post conmments that contain an email address.
May i know, how the bar are inside the tv? You can use this link to see whats the problem is, http://www.fastrepairguide.com/plasma-tv-pdp-information/how-to-describe-explain-the-plasma-tv-problem-or-sym.html
After you read this article, now you will know what's the problem of your plasma tv.
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
hi all .ive had the same problem,a thick black line down
screen.sometimes it flickers from top to bottom and other permantly in
view.but i have solved it.forget your ic boards and taking apart tv.have
you got either a ps3 or wii connected to tv.if so unplug power lead
from socket and relocate in seperate socket.make sure the lead is
completely free of any other leads and you might just find this works.i
think the power lead creates some sort of frequency that the tv picks up
.good luck hope it works
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
All I can say is when you watch T.V. the plasmas run off of plasma gas and when you leave something on for so long it burns in the screen. I have the same T.V. and when watching like the weather channel it leaves lines but they go away. If yours are permanent then you can't do anything, but it may help if you go on your remote and go to "menu" then look for "setup" and scroll down with the arrows on your remote. Look for "screen burn protection" and select "white screen". This will make your whole screen white and it may take out the lines. If you let it sit white it won't hurt it. All one color won't hurt, the only thing that hurts is like bright white lines in front of a dark background. Just give your T.V. a break from time to time ESPECIALLY ON VIDEO GAMES. T.V. shows that are HD usually have their channel icons that move or are very dim and they won't hurt. Just go to what I told you and let it sit about 20 minutes, if that doesn't help, then the T.V. you have i believe comes with a 2-year standard warranty and if it's under warranty take it back if you have the reciept. If you don't have the reciept then call 1-800-SAMSUNG.
Ok if your hitachi TV dies with no power anywhere try this: Some models have a kill switch under the bottom edge. It's like a gray switch like a small light switch press it back in and voila let there be LIGHT. Saves you at least a $200 trip to repair shop!!
Thanks
