Check the home button maybe its stick with something making it on always, try to clean the button.. unless you don't know how to stop shaking the apps its with pressing on home button..
The auto mode will not necessarily work when there is hand shake , it seems that , it will remove slight hand shakes and blurs , but that's not what it's meant for.
The auto mode is like a sensor to the surroundings and then adjusts the camera exposure and color settings accordingly.
Therefore remember whenever you take pictures , not to move the camera and it's always better to focus an image first by half pressing the button and then when the image is focused and green dot is coming on the screen , you go ahead and press the button fully.
Hope this helps ..:) Your feed back would be appreciated.
Nikon does not have a remote for the P100. However, you can use the self-timer to reduce camera shake. Press left on the multiselector (marked with a one-handed clock) then use up/down to select "2s" for a two-second delay.
Admittedly this is not a perfect solution, since you have to anticipate the shot. However the delay will give the camera a chance to stop shaking after you press the shutter before taking the shot.
The shaking hand icon has to do with the Image Stabilization control. If it's continuously shaking, it's set in continuous mode, etc. You can access control for the "I-S" via the menu...scroll down to IS settings. and you can adjust as desired.
If you have a protective screen on the phone take it off. If this works replace the screen below the LG logo this way it doesn't cover the sensor on the left hand side.
My laptop is not working in the proper manner.Because for the screen the belt is may be some loose contact.some times the screen is shaking at the time of booting and immediately hanged.Then system is not working.Some times if we press upon the screen then it will work in good manner.If we remove the pressing hand,immediately the screen shakes and hanged the contents immediately.
ok. bear with me. lol. on most watches without a chronograph. the second is the largest hand on the watch and naturally that's what most people refer to as the second hand. On a chronograph the "true" second hand is the little middle dial. It should always be constantly moving and the large hand should only move when the stop watch funtion is in play. The way to employ the stopwatch funtion is by unscrewing both buttons. The top button starts the action. Once pressed then large hand will begin. The little dial on you left will keep up with each minute that passes. To stop the function, press the top button again. To reset the stop watch, press the bottom button. The little dial on your right is simply military time. Hope that helps. Good luck!!
