Quickbooks simple start 2009- error message appears when i try to open "quickbooks has stopped working" "a problem has caused quickbooks to stop working correctly"
1. Do you have a backup of your quickbooks from before this started happening? If yes, try opening the backed up quickbooks file.
2. Uninstall Quickbooks 2009 completely, then reinstall it and check of updates and install all of them, then try it again.
If the problem persists, please let me know so I can continue to help you. These are the first two things to try and would be the easiest solution.
Thanks for using the FixYa forums!
specially, the Indian commercial mortgage sector witnessed a sea of change in the last 15 years. The last decade and half witnessed an astronomical rise of the Indian manufacturing industry which accelerated the growth of infrastructure industry in India. Furthermore, with the growth of infrastructure industry in India, the Indian mortgage loan industry witnessed a tremendous growth.
Commercial Mortgage
QuickQuickBooks is a dynamic application that meets all the requirements of your company. It has an excellent function that enables you to readily finish your duties related to your work. But many times there are bugs and crashes that ultimately destroy your job and attempts. While installing QB, QuickBooks error code 6130 appears, it requires to be reinstalled. You will receive a signal of mistake: "Your installation of QuickBooks may have been changed. Try to reinstall QuickBooks and attempt again "(-6020, -100). However, QuickBooks error code 6130 may not allow QuickBooks to access the network owing to numerous other factors such as firewall or anti-virus software.
There are many reasons behind this error and to solve this error now. You can call on this toll-free number +1-800-961-6588 anytime or visit this website.
https://www.remoteaccounting247.com/quickbooks-stopped-working/
I opened my Quickbooks EasyStart 07/08 and it keep closing for some reason. I had not used it in a couple of months, but it was working before. So I reinstalled it. When I accept the agreement, I recieve an error message. "Quickbooks - Unexpected error" It has encountered a problem and must close.
I removed the software, reinstalled it, and the same thing.
Please help.
Thank you.
By the way I am on Win Vista Ultimate also running Office 2007.
