Hi I hope you can help I'm very confused with prescribe, I want to be able to print a three page Microsoft word document to a printer with two trays, I want the first page to print from the first tray and the second and the third page to print from the second tray. Hope to hear from you Kind regards Belinda
Once you have installed and setup a multi-tray printer you might like to try to print a document to different printer trays. Open a word document and create a two page document.
SOURCE: Printer - Setup
USB-interface; CU- custom format of paper; Plain- paper type.
Default settings in the menu of the printer is: A4 or letter,plain
That is the same thing in the printer driver. Also check format of paper settings in small window of your paper cassette.Turn roller to adjust proper size of paper.
Best regards
SOURCE: Not printing
Had the same problem - in the end it was that the paper drawer wasn't closed properly.
SOURCE: Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
SOURCE: colour band at base of page
Check for the latest print driver and eventually for the latest firmware. You may have to switch the print driver to PCL instead of KPDL (Auto). Ask your service provider to do that if you don't have the knowledge.
SOURCE: set up KYOCERA FS-1350DN printer
you need to scroll thru your menus...paper handling section...make sure mp tray is set to FIRST..that way it will pull from the mp tray untill it is empty than switch to your cassette
