Question about Nextbook Premium Series Next7P12
No sound when headphones are plugged in - Nextbook Premium Series Next7P12
    New Friend:
  • 43 Answers
You have to have headphones that are equipped for that device. I use Apple headphones for my Nextbook 7Premium Android device. It depends on what type of headphones you are using? You also have to push hard on the piece that goes in. Sometimes they don\'t go through so you won\'t be able to hear at all.
Posted on Aug 01, 2013
6ya staff
SOURCE:
My headphones are plugged all the way in but its coming out of the headphones and speakers , can you help ?
If I uderstand correctly, you mean you have your headphone plugged but SOUND is coming out both from headphon AND speakers?
As I understand your plug socket is defective and you should replace it. This may sound easy but it's not so bacause it means disassemble your tablet.
It it's on warranty, take it for service. If not, you'll have to spend some mone repairing it
Just for an IDEA, watch this video, it's for an iPod
How To Fix iPod Headphone Jack Socket
Aug 28, 2015 | Proscan 7-Inch Android Internet Tablet,...
My headphone jack not work when i put it in my tablet i can still here the sound from my tablet and the headphones from the tablet it is a irulu Tablet,
Make sure you push the headphone plug into the jack completely. If you're sure that it is, then the jack on the tablet has failed. The sound gets switched from speaker to headphone in the jack itself.
Aug 08, 2015 | Tablets & eReaders
When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
This can be a hardware (bad headphone jack) or a software (rom update) issue. If the tablet is in warranty, try taking it to your dealer and see if they have a fix.
Otherwise, some people have had success doing one of the following:
1. Plug headphones in after starting music. Watch for headphone icon to appear on screen, meaning tablet has recognized that headphones are attached. Make sure plug has been put into socket all the way.
2. Install app SoundAbout on your tablet and see if you can route sound to headphones only.
3. Check Settings/About Device to see if there is a software update for your tablet. Install the update and see if that fixes the problem
Jan 12, 2015 | Samsung Galaxy Tab 101 Tablet...
My sound on my kindle fire hd is not working, only if I have earbuds, headphones, or speakers plugged into it
Sounds like it should be returned, if still able to. There is most likely a cold solder joint or wire, but i dont believe it is user repairable.
Oct 22, 2014 | Amazon Kindle Fire HD
How do i fix this? When i plug my head phones in the sound goes away.
that's the way it works if you plug in the headphones the external speakers go off. if you are not getting sound to the headphones then try another pair of headphones to see if they will work.
Jun 08, 2014 | Google Nexus 7
No sound
Do you get sound when headphones are plugged in?
Dec 10, 2013 | Samsung Galaxy Tab Tablet PC
Headphone jack on kindle fire doesnt work
If the sound works on your Kindle Fire's speakers and will not cut off and reroute sound to headphones when you plug them in to the headphone jack port on the side of the Kindle. Try the following:
If you have a set of blu tooth headphones then enable blu tooth connection to a source of sound like, You Tube, Spotify iTunes etc. You will be able to hear sound on your blu tooth headphones this way. Turn of the blu tooth headphones, then try plugging in your regular wired headphones into the Kindle and reconnection should be achieved.
Jul 07, 2013 | Tablets & eReaders
No sound from built in speakers.
The bleep cold be just a bleep device separate from the speakers. It looks like a round piece of aluminum with a large dot of white solid past on it with a wire attached.
1st. make sure the volume is up all the way.
Then try using a headphone just to make sure the sound card is working.
If the headphones work then it should be a setting somewhere.
Sometime the switch that turns off the speakers when headphones are plugged in gets stuck, try plunging them in and unplugging them out while music is playing.
If they don't work the sound card may be blown but it is still possible it is not.
Also, try Keyboard shortcuts for mute and UN-mute.
Try going to control panel and bring up the sound app and try different options in there for mono and or what ever it has, you may find the answer there.
If the headphones work but nothing else works you can always plug external speakers in the headphone plug.
Sep 28, 2017 | Toshiba Tecra M4-S435 Tablet PC
Fujitsu T series; no sound when I plug in the headphones
I have the same problem and just figured it out. Go to the sound settings and set the earphones as the default. I just did this and it now works.
Nov 27, 2008 | Fujitsu LIFEBOOK T4010 Tablet PC
Nextbook Premium Series Next7P12 Logo
330 people viewed this question
Top Nextbook Tablets & eReaders Experts
 Mike M
Mike M
Scott Fryer
john smith
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
