Question about Dell Computers & Internet
PC power supply fuse - T6.3h 250v engraved on end
Radio shack 250v 3 amp fuse found in store, fast blowing, does not look the same - original has what appears to be a ceramic body, fuse from store has clear glass tube. I don't know what the ''T6'' stands for or if the original was slow-blow . Can't find info for direct answer. What does ''T6'' mean? Why ''T6.3H'' not T6.3A. Circuit board label at the fuse: ''T6.3AH 250V'' Will radio shack fuse work? Is there a website to explain nomenclature(s)? All info I found is incomplete.
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Posted on Aug 05, 2009
Anonymous
SOURCE:
Replacing a tv fuse 8A 250v with an 1/2-Amp 250v
Load fuses are rated. The ratings will be marked at the PCB, very near to the fuse holder. Do not use a fuse, which have more ampere ratting than specified. It will make things worse. If fuse burns out, as soon as the set is switched ON, be sure that there must be some shorted component/s at the power supply regulator section circuit. Check and rectify the fault first, before inserting an other fuse of same rating.
Mar 01, 2013 | Televison & Video
I need a fuse for my Durabrand Home Theater System HT-3917. The fuse is T 1.25AL/250V. Where can I get that fuse?
TRY MAPLINS OR A ELECTRICAL STORE OR EVEN A DISCO SHOP WILL STORE THESE FUSES.
TAKE THE OLD ONE WITH YOU AS THEY WILL NEED TO KNOW IF IT IS FAST BLOW CAP ON EACH END WITH A SINGLE WIRE INSIDE OR NOT (IS THERE A SPRING AT ONE END INSIDE THE GLASS TUBE THIS IS CALLED A SLOW BLOW FUSE).OR IS IT IN A CERAMIC WITH A METAL CAP ON EACH END.
HOPE THIS HELPS
NORMAN
Aug 23, 2011 | Durabrand HT-3915 System
I am trying to locate a fuse for a Sanyo plasma model number dp50747 it is the fuse right next to the power suppl. it shows ft10ah250vp on the fuse
thats a 10 amp fast blow fuses rated for 250v
You can get them at any Radio SHack Store
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Apr 01, 2010 | Sanyo DP50747 50 in. Plasma TV
Hi there we have a la cimbali m30 dosatron and someone has pulled out all the fuses on the pc board and we need to know what sizes they are to replace them. Thanks Simon
There usually no fuses on a M30 dosatron unless it's the "L" shaped supplemental supply board which has a small 250V, 6 3/4 A fuse (half the size of a normal glass tube fuse). Most boards use a similar size but rated at 4 amps for the PC board power protection. The only other fuses (older models) have big 10 amp jobs for the main power to the heater elements. But this has been replace with safety relay and or high thermal limit breakers. you should be able to find both at a hardware store. The smaller fuses at Radio shack or electronic store.
Oct 21, 2009 | Espresso RMI La Cimbali Espresso Machine
Magellan Maestro 4250 fuse
It is a Fast Fuse Glass type 5 x 20mm, 2A, 250v. Magellan 4250 can only take 1A of current at 5Volts Radio Shack
Jun 10, 2009 | Magellan Maestro 4250 GPS
I got a Galanz microwave Moldel # P60D17L-D5 and cannot find a ceramic fuse anywhere it's 3/4 inch long and 1/8 inch diameter. I've tried emailing the company but no reply's.Anybody got any idea's
The microwave oven use a slow-blow fuse. If you look on the around the end of the fuse, you will be able to tell what size it is. Example (250v 3Amp) Your fuse may be found at Hardware stores in the electrical isle or a Radio Shack. If you found my suggestions to be helpful, please rate my solution. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Aug 14, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
May 15, 2008 | Altec Lansing Multimedia Computer Speakers
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Open Questions:
Dell Printer@^+[1]=855-221-4867@&@tech Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
10,667 people viewed this question
Ekse
Thomas F. Schneider
Shawn DuRee
