It's not defrosting and the fan inside is hitting the ice and stopping the fan which is not cooling the fridge. Why is it not defrosting ?
One of 3 things cause a ref not to defrost. Defrost timer may not be advancing to the defrost position on the timer...The defrost thermostat, located on the evaporator in the freezer, is measures open bad)...or you have a bad defrost heater. If you have an electronic defrost control,which is used on most Maytag, Jenair, or Amana units, this could be your problem. If you turn the unit off for 24 hours to let it defrost manually then it will last for about 2 weeks before freeze up again.
The defrost is not working and the fan is hitting ice buildup...
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
