A dent will not affect tracking unless it cause a gross deformation of the hull which actually has a steering effect to push it one way or the other. This would be quite a big dent, or right on the bow or maybe stern. Tracking is more related to paddle skill than almost anything else, although some short boats, especially white water boats, are hard to track. Many kayakers paddle harder on one side or the other without realizing it. It can be hard for even an instructor to identify what is causing it.
Oilcanning is a fairly common problem usually caused by improper storage or transport of your kayak, especially if it's hot out. Gently heating your hull (either by laying your kayak upside down in the sun on a warm/hot day or by using a heat gun CAREFULLY) MIGHT pop the dent out. If you were dealing with a single-hulled kayak, a little gentle pressure on the area with the dent while it's warm/hot would definitely do the trick. Not sure how I would approach a double hulled kayak, but it would probably be a combination of heat and pressurizing the inside of the hull or heat and water on the inside of the hull...would have to experiment.
"used one of these while on vacation in canada,and i'm hooked it was very sable on rough waters,and we also took it out and went fishing ."
Bottom Line Yes, I would recommend this to a friend
"The Future Beach Freedom 160 is a nice stable boat with a rugged and durable build. Due to it's weight the boat is a bit on the slow side and a challenge to move around. Storage at the front of the boat is limited but could be expanded with a small modification. I am sure that this would be a great boat for fishing and other water sports (i.e. snorkling, SCUBA)."
"Love this boat, Amazing Quality, superb tracking
An absolute pleasure to use !!!!!!!!"
oops,,,,,,,that should read Venus 10 not Venus to
