Question about Sony DCR-HC26 Mini DV Digital Camcorder
My touch screen buttons stopped working, and now I cant play back or even put footage on the computer. I try to click the touc screen buttons but it doesn't work. The recording and everything works fine, but I cant get my touch screen buttons to work. Please help?
  • 892CCC Nov 28, 2009
    Sony's flat rate cost to repair $230 camcorder is $211. Sounds like a rip off for a camcorder that was babied, and used less than 3 hours over a period of 3.25 years. I think this is defective engineering and would refuse to foot even a quarter of that bill. In fact, I'd sooner burn the corpse of this one, and buy a Panasonic for that much.
    And guess what? I opened up this camcorder and there's nothing wrong with the wiring, nothing pinched, nothing ripped, nada, zilch, zero.
    Where can i find parts? I'll fix it myself. Or smash it. Either are the only options.
  • 169 Answers
The flexwire is the problem of your camera and if all wiring be cut the next problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...
Posted on Sep 01, 2007
Anonymous
SOURCE:
D touch screen buttons on my Sony Hvr-a1p video camera does not work. I can't rewind, forward or even play video back.
Hello, try to reset the camera, if you need more help to repair your video camera i found a factory service manual for it you can download from the below link:
http://goo.gl/Ji4XI
Good Luck
Apr 19, 2013 | Video Cameras
My iPhone 4 buttons have all stopped working and I have to use assisted touch. Now I can't get that to work either; I am stuck on the screen (photo attached) and can't access anything. When you...
First
You have to Restore your iPhone via Itunes
Then check if the problem is solved
Second
If the problem hasnt been solved after Restore ,this means that the Touc Screen of your iPhone is need to be replaced with a new one
Note : The Touch Screen of the iPhone 4 is not seperated of the LCD screen,so you have to change the Whole screen (LCD and Touch Screen
Jan 26, 2013 | Cell Phones
Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
Sep 09, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
My sonyericsson k850i touch screen is not working
Sir, try reinstalling your phone. This will make the phone to be back to its original settings and maybe can bring the phone's touch screen capability back.
Jul 19, 2009 | Sony Ericsson W850i Cellular Phone
Touch screen not responding
Hi, I have the HTC touch from bell. I too had the same problem with my screen. It stopped working completely. The phone is pretty much useless without the touch screen working, there is only 3 buttons on the phone! Can't even dial 911... So I was pretty pissed when the screen stopped working. Like others I searched the internet for answers and didn't really find too much. I found that maybe tapping the four corners of the screen firmly might work, but it didn't. Taking the protective cover off the screen might work, didt't work. I tried updating the ROM, using the official software from HTC website. I was able to update my phone, but my touch screen still didn't work. Someone said something about some copper connections inside the phone, need to be re-adjusted behind the screen or something like that. So I willing opened the phone (only 4 hex screws on the back) and took the front plastic cover off. If you look closely, you'll see the front cover is plugged into the 'motherboard' and you can simply unplug it. I unplug it and plug it back in, do a restart of the phone (take battery out and back in) and still nothing, screen doesn't work.
I noticed that on the front cover of the phone (underneath) you can see the copper band of wires that connect to the buttons and probably feeds the information from the touch screen to the 'computer'. I accidentally unplugged the wire (thought I broke it) but was able to insert it back in. I put the the cover back on, put the battery in, power up phone, BINGO! Touch screen works! What I did to make it work? Not sure...
But for people with the same problem. Try this:
1) update ROM
http://www.htc.com/us/SupportDownload.aspx?p_id=70&cat=2&dl_id=98
2) Unplug and plug back in that little wire.
http://img81.imageshack.us/img81/1912/htctouchx.jpg
Its the red circle I'm talking about.
Jul 17, 2009 | HTC Touch Cellular Phone
Touch on touch screen phone not working
Hi, I have the HTC touch from bell. I too had the same problem with my screen. It stopped working completely. The phone is pretty much useless without the touch screen working, there is only 3 buttons on the phone! Can't even dial 911... So I was pretty pissed when the screen stopped working. Like others I searched the internet for answers and didn't really find too much. I found that maybe tapping the four corners of the screen firmly might work, but it didn't. Taking the protective cover off the screen might work, didn't work. I tried updating the ROM, using the official software from HTC website. I was able to update my phone, but my touch screen still didn't work. Someone said something about some copper connections inside the phone, need to be re-adjusted behind the screen or something like that. So I willing opened the phone (only 4 hex screws on the back) and took the front plastic cover off. If you look closely, you'll see the front cover is plugged into the 'motherboard' and you can simply unplug it. I unplug it and plug it back in, do a restart of the phone (take battery out and back in) and still nothing, screen doesn't work.
1) update ROM
Jul 07, 2009 | HTC Touch Cellular Phone
Ipod touch password
put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for 10 seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and click on your ipod on the left. then click restore. this should work.
Dec 27, 2008 | Apple iPod touch Second Gen (8 GB,...
Bottom screen wont work
Have you attempted to recalibrate the touch screen?
Since you can still use the navigational buttons,
From the main menu:
1. Click the "Settings" button. It is the button at the center bottom with the DS on it.
2. Then click the "Touch Screen" button. That is the one with the Yellow Crosshair on it.
After that, proceed to calibrate your touch screen.
Let me know if that does not work.
Dec 09, 2008 | Nintendo DS Console
Broken touch sensitiev buttons
When you enter your pin press the hash button, this will let you into your phone!
Jan 06, 2008 | Samsung SGH-D600 Cellular Phone
Sony DCR-HC26 Mini DV Digital Camcorder Logo
587 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
