All of a sudden, all media related icons (email, browser, CV media) disappeared and phone says no media card is inserted. This occurs when SIM Card fully inserted to left in slot. If I move SIM card slightly to right, media functions come back but phone will not initialize and tells me that valid SIM Card not inserted.
The first step I would recommend is to re-seat your SIM card. To do this locate the SIM card slot, and remove the SIM. Make sure there is no dust or dirt making your phone not recognize the SIM. After doing that reinsert the card and then try restart your phone. After a few seconds you the warning should disappear and your phone should be working normally again. If this does not fix it my only other suggestion would be to contact Apple or your phone provider and discuss getting a new SIM card.
It is possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Copy only valid files to the card and do a scan before it is replaced. Now replace the card and battery and switch on the phone. If the phone hangs up or is slow when it is switched ON , then it is possible that the fault is relative to the software and will need a reinstallation. Possible hardware issue cannot be ruled out.
please try it. friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step 1) cd\ press enter 2) c:/>format drive letter (eg d: f: e: etc) press enter 3) read message carefully and then press y now yours flash drive formatted
You must move the music files
to the appropriate folder on your micro card. move all the music to the "sounds" file. Your phone is not
set up to read the entire card, just the folder associated with the
application being used. If this doesn't work out, then copy the entire
card to your desktop and format the card while inside your phone from
your phones menu. Now insert the card and select, open to view files.
you can now locate the appropriate file and paste the songs you would
like to have on your mobile device.
Good Luck And PLs Rate This Post!!!! :D
P.S. Look carefully at the layout of your card from the "view folder" option when your computer recognizes it. You should see one called DCIM........open it and you will see a folder for the other options in your phone. You MUST place the files in the folder that your media player reads from. It will be either "Music", "Sounds", or some other name that is related to music or sound.
Just go to your options, and click "themes". Then hit "restore theme defaults" and the icons should reappear.
You might also want to got to options menu in the email messages. It appears as you have a combined inbox instead of a separate one. There is an option that says SMS AND EMAIL INBOXES with three options: Theme controlled Combined Separate
try removing the battery from the Blackberry and replacing after a couple of minutes. this will completely reboot the software. Let me know if it doesn;t work and we can go another route.
you put your memory card on other mobile.
if it works so you have to repair your hardware and if it doesn't so change ur memory card
Fazel [email protected]
