JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Posted on Apr 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is really wrong with a jvc television? I heard the light bulb goes out ever three months, is that true? Barb
Sonny Berry
Level 3:
  • JVC Master 8,617 Answers
  • Posted on Apr 03, 2009
Sonny Berry
JVC Master
Level 3:
Answers
8617
Questions
Helped
1721691
Points
23750
The AV56WP74 is a three CRT rear projection which has CRTs ( Picture Tubes) It doesnt have lamps or Bulbs
My echo 210 primer bulb does not fill only pressurizes the tank
The fuel line hook up is wrong. Ok, so look at the two nappies on back of the bulb assy. The long nipple is for the fuel return line, (the line without the fuel filter that returns to the tank) the short nipple , that line goes to the fuel barb on the carburetor, on the same side as the bulb assy.. then on the opposite side of the carburetor find the fuel barb, connect the fuel line to that barb and into the tank where the fuel filter is on the end of that,... If you have trouble understanding what I mean, hmu.
Brian
I have a jvc ilha tv I replaced the bulb 5 months ago the last 5 weeks it has been really dark picture i replaced with a generic bulb and was fine at first any recommendations?
you need to get the original bulb from the company's authorised service dealer. these bulbs are of very specific type. & will work with same type only.
2helpful
I have a JVC-HD projection TV model 56G786 and all of a sudden it will not power on. When you try to turn it on the blue light on the power button goes on but after a few seconds it starts flashing and...
The JVC 56G786 users manual will not give you a clear or specific answer about confirming bulb failure with the LED lamp or power indicators located on the front of the TV.
If the TV was operating normally for an extended period of time (months or years) and will not start, the problem is almost always bulb failure. If the "Lamp Replacement" warning previously appeared "On-Screen" and the TV will not start, bulb has failed.
The first step in a "no picture" situation with a JVC LCD Rear Projection TV is bulb replacement. There is no way to measure the bulb. Sometimes the bulb is visibly broken or damaged when it fails. Remove the lamp cage and have a look.
The JVC Lamp Gallery has all the JVC models and lamp numbers listed. There is also a link to DIY JVC bulb and lamp installation.
If a good bulb is installed correctly and the TV still does not start, you need a technician. There are no user serviceable parts other than the bulb. Failure of ballasts, power supply boards or controller boards is rare in these TVs.
easyab
1helpful
TV was on and had a picture, and then nothing w/flashing power
Your lamp has blown. Time to get a new one.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
http://www.discount-merchant.com/JVC-LCD-Projection-TV-Lamp-TS-CL110UAA-TS-CL110U-p/jvc-ts-cl110uaa-hd-56fn97.htm
1helpful
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
8helpful
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
