SOURCE: ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it. 2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
SOURCE: Dispenser problem
nope. if your ice maker is making ice, then there is no problem with your water filter.
i'm thinking you have a problem with the micro switch that is being triggered when you press the dispenser. or the board where it is attached to choose from water to crushed or cube...
either one of those but definitely not the water filter.
tnx 4 using fixya,
drcool
SOURCE: Refrig Ice is freezing up on the door dispenser
Most likely the defrost timer or Adaptive defrost. Yours has the defrost timer. I want you to open the fresh food compartment and find a small opening through the control panel. The opening may have a plastic plug covering the hole to hid it. Remove plug and turn timer clockwise slowly until the compressor stops running. The compressor should remain off for about 25 minutes. If it does not turn itself back on then turn the timer slowly again to the right/clockwise until it does. If you need to restart the compressor. this way the timer will need replaced.Defrost timer is part number 482493 Keep me informed on your progress, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
SITE2=> http://appliancepartseast.blogspot.com/
