Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
SOURCE: My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
SOURCE: cannot faind Ricoh Aficio SP C410DN Laser Printer driver
you can find the driver here http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11540&ricohmodelid=6342&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fcl410%2Fcl410en%2Ehtm
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
SOURCE: Model No. In Ricoh Aficio
Model No. In Ricoh Aficio sp 1100sf
Error Massage displayed (Printer error fuser temp.
