I play Rise of Flight with an old (and very good) Sidewinder 2 Pro for more than 2 years with no problems. But now the HAT settings changed, the cockpit snap views are not controlable as before. It zooms when I look to any of the sides, and also it lost the intermediate view positions, which obligate me to use the mouse in order to look the surroundings in any directions. Would somebody please give a help on how to set the settings back?
usually the drivers come with the CDs if its not there try re-installing if it didn't work download a free driver scanner and look if you have any out of date drivers :) .
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
O-the sweet feel of a Microsoft Sidewinder Force Feedback lets see if I can be of some help. there could be any number of things going on but I'm going to give this a try. have you checked the settings in Flight Simulator 2004 seems to me that I remember a check box that said disable force feedback make sure that is unchecked. also in the settings for your controller there is a box that says enable force feedback make sure that is checked. then make sure if you are using a firewall like zone alarm you are in gaming mode because this used to give me major headaches with my system to the point I had to detach from the internet and shut down my firewall to play my games. if this doesn't work you may have to reinstall the drivers for the sidewinder this is the last easy option and it should repair any broke links and reset itself into your system. Please let me know how this helped if you need more Ideas just contact me.
You need to assign what view you want to the cooley hat on your controller in FSX\Settings. Rethe Zoom, press the backspace key to reset it, then use the + and - keys to zoom in and out.
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
I have same stick, that same software wont work with xp or vista depending on what game you have you should be able to set up in input settings for the game , there was a patch at one time that someone made up you mite want to try here and do a search > http://forums.ubi.com/eve/ubb.x?a=frm&s=400102&f=49310655
