Jbl subwoofer pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
