Can anybody tell me how to Reset an N96 back to factory default settings please??? This is kinda proving difficult to find.Many Thanks for any help in this matter in advance...
Yes i can help go onto your main menu and click onto TOOLS...then click SETTINGS .. then GENERAL.. go down and it will say Factory settings click FACTORY SETTINGS.. it will then ask you for a code teh reset code is 12345! hope this helps :) your phone will automaticly re start but may take a few minuits to re start dont panic just let it load and it sould be fine howere avoid doin this to often x
On the idle screen of your phone press *#7370# and it will ask if you want to restore the phone to factory defaults? Select yes and type the security code when asked (default is 12345) phone will restart, now press *#7780# and follow the same sequence.
I have problem with n96 to connect web via wifi... there are error no return gateway
My keypad does not work after 5 mins and i want to reset my mobile
I HV TRIED TO RESET BCOZ MY PHONE CAN'T MAKE A CALL TO SOMEONE.AND THEN IT DOESN'T WORK.WHAT SHOULD I DO??
I would like to reset my phone... i have a nokia n96 and noyhing works
Alawa mansour
Nokijan96
I still can not restore default with the code 12345, or key screen *#7370# or 7780. can not , how?
Wow Jay many thanks and all now all factory settings is resetted with the code 12345...I would really hated to put the 500 plus number back in the system. Ramji
*#7370#
Hard Reset
Hard reset only works if you had previously updated the phone to v20.
Please make backup before applying this type of reset, since it will
restore the phone's settings as well as erasing all the data in the
phone memory, including take off your memory card.
*#7370#
Hard Reset
phone memory.
i would like to reset my phone... i have a nokia n96 and noyhing works, blutooth, gprs, nor does it pick up that there is a memory card in it. please assist, desparate mohamed
