The freezer has ice on the bottom, under the baskets. I have no idea where the water is coming from, though it looks like it comes from the vents at the top. The ice maker isn't connected to the water so I know it isn't leaking. Where is this water coming from and why is it puddling into frozen blocks on the bottom?
Every ten to twelve hours your refrigerator activates a heating element around the evaporator to defrost the accumulation of frost that develops on the evaporator. Behind the back panel there is an evaporator pan it has a rubber grommet with a hole in it this is your defrost drain hose it is clogged. Unplug or switch refrigerator off at breaker panel, remove panel covering evaporator area (rear panel in freezer), use a hair dryer or hot water to unclog defrost drain a turkey baster works well to make sure the hose is unclogged.
the water that drains down this hose accumulates in the defrost drain pan in the base of the refrigerator under normal operation the heat from the refrigeration system evaporates this water. The drain pan has a limited capacity so do not poor more than 20-20oz of hot water down the hose after you unclog it. If you poor to much it wont hurt anything just make a mess youll have to clean up.
thanks for the help. I'll try this at home and hope that it works. Have a great week!
