Sewing Machines Logo
Posted on Apr 02, 2009
Janome memory craft wont go forward
Broke a needle on sewing machine and now it is stuck and will not go forwards even manually, it will go reverse but not as smooth as it was, can get bobbin to go round and it looks like the feed dog is stopping it, how can i fix this
thank you
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Apr 28, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
0
Helped
1136
Points
Soulnds like you need a bobbin case.
Please I need to know the exact number of my machine needle, that I can be using it. My machine is Janome memory craft 6000
Hello, Sauban -
The needles you will use will depend upon the kind of sewing you will be doing and the fabric on which you are sewing.
The Instruction Manual for the Janome Memory Craft 6000 lists the needle sizes on page 22 of the manual:
https://www.janome.com/siteassets/support/manuals/retired/computer/inst-book-mc6000-en-new.pdf
The website SewingParts Online sells a variety of needles for use with the Janome Memory Craft 6000:
(TinyURL link): https://tinyurl.com/yb3oy2wo
The company is located in the USA.
If you do not reside in the USA, then, I suggest you use your favorite search engine (Google, Bing, Yahoo, DuckDuckGo, etc.) and the following search phrase, with quotation marks as shown to find needles for your machine from a business in your country of residence:
Janome "Memory Craft 6000" needles
Best wishes.
When I have the walking foot on the needle hits on the back of the foot.Janome 4800 memory craft
Is it a Janome brand walking foot? some generic feet and other brands don't fit the older Janomes.
2answers
Janome 9000 motherboard fault?
I would suggest to get another option, those motherboards are
expensive
6helpful
2answers
Janome Excel 5124 reverse lever
If you pull the bottom off the machine (half a dozen screws) there is a cam on the main drive shaft. The cam is probably jammed in the reverse position due to lack of lubrication on the shaft. You can move the cam back manually and it will operate in forward direction. It appears that the shaft needs lubrication.
3helpful
2answers
Janome MC 10001 auto. needle threader stuck in up position.
You are threading the top of the machine incorrectly.
Make sure the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly. If this does not solve your problem, please respond.
Janome 9000
I have a Janome 9000, was sewing and broke needle, replaced and broke another. I didn't have machine threaded, took out bobbin and would sew a little and stop saying thread broke. I took off top plate and started machine again, sew a little and stop saying thread broke. So I took out bobbin case and sewed again and stopped repeating the message. Everything looks OK, bobbin case and top plate. I guess I want to know if the timing could be off or do you think it is the computer part of the machine...Should I take it to the Sewing Machine Shop??
Janome Memory Craft 4900 QC
its the sensor on the bobinwinder who are loose. If you are handy. you can remove the top cover of the machine.
And on the left side of the bobinwinder you will find a micro switch. Probably you have to tighten the screw on it..
3helpful
2answers
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
