'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
E08 error message which indicates papert jam is caused by lose or mis-alligned input paper tray (automatic document feeder). Resolve issue by powering off the scanner, opening the paper path section, removing the adf, and then re-seating the adf.
Wat is the code about this problem 08-300 its maine the Füser is not start on the same time when the cluts is not werking oder the pall is not gooing to this point open the front dore an you cann sche small cluts this is no good contact of its not working then you can puss the small wiel to the bik rol en the paper wil to the füser turn the green wiel and the paper go to füser out. I had this problem also with Xerox 5760 the same .
Clearing Paper Jams If your scanner stops scanning due to a paper jam in the Automatic Document Feeder, a warning dialog box opens after a few moments. To clear a paper jam: 1. Press the ADF cover release on the top-left of the scanner body to open the Automatic Document Feeder cover. 2. Remove the jammed paper and close the cover. To reduce the number of paper jams, smooth and straighten the paper before scanning and adjust the guides to the paper size.
This should help. Please let me know if it does. Thank you, Binary Bob
