I restarted my phone and now when I turn it on there is no response when I try to slide the bar down to unlock it. the icons are there at the top of the screen, however, the clock is wrong, the background is just a black screen, and the two clocks say a different time, neither of which is correct.
SOURCE: Want to remove the clock
Just follow this
- press "Start"
- choose "settings"
- enter "today" in the first tab named "private"
- choose the second tab named "Elements" or something like that
- toggle "HTC Home"
- press "OK" in the right top corner of the screen
- no more clock on your screen
SOURCE: Incorrect time showing on face clock
in that case... remeber to set your phone into an automatic time and date update. You can find it on the settings menu and there goes.. its done.
SOURCE: HTC Tilt phone- Digital clock has replaced by clock with hands
Current time (tap and hold the time
to change display modes.
Here is the User manual:
http://www.wireless.att.com/support_static_files/manuals/ATT_Tilt.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: screen is on but blank except saying unlock and
You'll need to send the phone to Cell Phone CPR to have it properly
repaired.
Here's the link:
http://www.cellphonerepair.net/
SOURCE: I accidentally removed the clock/weather
It's actually a pretty simple way to add widgets back to your home screen.
Long press a blank area of your home screen. A dialog box to Add to Home will appear. Select Widget, and then select Clock [HTC]. You will be able to select from 12 different HTC Clock widgets. Select the one you like, and then press the Select button. It will appear on your home screen as long as there is enough room for it. You can move the widget around by long pressing on the widget and sliding your finger to the desired location on the screen.
Good luck.
