SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
SOURCE: MY LG WASHER WONT DRAIN, IT SAYS THE ERROR MESSAGE
OE is a drain error - Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
SOURCE: LG washerwon't spin
I had the same error code along with the drum "freezing" up. The first unit that was delivered 2 years ago leaked water from the detergent compartment and they sent a second unit. I have only had this unit for 2 years and I am very disappointed in the LG product. LG
was no help on the phone and I the only people that could service it
were 45min away from were I live. I took the advice of a posting on
this website that it could be a part called the sensor assembly and ordered it from an online electronics store (www.mcminone.com). To get to the sensor assembly, you first unplug and take off the back plate that has 4 small screws. Next, unscrew the big bolt in the middle and take off the hubcap looking part the bolt was securing. Next
unclip the two sets of wires on the bottom of the circle you are
looking at (the set of wires to the right are connected to the sensor
assembly you want to replace). Next you will unscrew the 6 or so smaller bolts to take off the circular piece that the sensor assembly is snapped to. Take it off, unclip the old sensor assembly and clip on the new one – and reassemble. This worked perfectly for me and the part only cost $18 bucks plus shipping. When working, this product works well but I will not be purchasing any LG products in the future.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Lg front loader makes squeaking sound and
The drum is powered by a small motor and pulley, inside the unit and under the drum. A large belt wraps around the drum and pulley, and a spring "thing" provides tension so that the belt won't slip. The squeaking sound indicates that something is slipping, and the sluggish drum says that it's the drive belt. Take off the back, locate the motor/pulley/spring thing, and check the belt tension by observing the belt with unit operating. At that point you should easily locate the noise, at the motor (noisy bearing, lube or replace), belt warn (replace) or possibly the felt pads located at the top of the drum worn (not as likely but they do fail causing the drum to resist being spun by the motor to the point that the belt starts to slip. Hope this helps!
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
