SOURCE: Saeco Incanto Classic Espresso Machine Saeco
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : [email protected]
SOURCE: Red light far right blinking continuosly (#26)
Hi jason,
The flashing red light indicates tha _something_ is not positioned correctly. Please check and see if you can find the sensor(s) that determine whether or not the components are correctly positioned.
You might also try unplugging it for 10-20 minutes to allow any electronic sensors to reset when you reconnect power.
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
SOURCE: Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
SOURCE: Hi, I just got my new rancilio yesterday and used
No the temperature is fixed. If you make the coffee just after is heated up 10-20 minutes then try to lush some water from filter holder first in the cup you will serve the coffee. Flush for some half a minute and the make the coffee.
SOURCE: There is a flashing warning
Mostly it is just a very unreliable product. I am on my 3rd replacement after only 14 months.
