Question about Splendide Washing Machines
My Splendide 2000 washer/dryer combo will not agitate the clothes during wash cycle, spin in spin cycle, nor tumble in drying cycle. Sounds as though it is going through cycles, but clothes just sit there. Please advise!
    Top Expert:
  • Splendide Master
  • 10,627 Answers
Check belt or motor
Posted on Oct 29, 2017
6ya staff
SOURCE:
Dov Dror
  • 641 Answers
SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
Posted on Jun 02, 2006
cheapiephp
  • 68 Answers
SOURCE: Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Posted on Jan 17, 2009
Anonymous
SOURCE: Hotpoint bwd129 washer dryer won't dry my clothes.
my Hotpoint dry will not dry my clothes. It will run for hours and the clothes still haven't dry just felt hot.
Posted on Jul 23, 2009
Anonymous
SOURCE: Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Posted on Dec 02, 2009
Anonymous
SOURCE: washer will not spin out water but turns during wash cycle
Try cleaning out the trap. It is located under the door and can be accessed be removing three screws at the base in the very front of the washer. The trap is white and screws to open. Watch out though, because if the washer is full of water it will come spilling out! With the trap removed, you should also use your finger to feel the opening of the pump to the side. I found a few bobby pins in my pump, and once they were removed it worked again!.
Posted on Jan 31, 2010
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Splendide 2000 combo stops midway in the wash cycle. What is the cause and how can I fix it please?
If it doesn't go from the wash to the dry, check to make sure that both the washer and the dryer are set before the start of the cycle. It also could be blowing a fuse.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 13, 2010 | Splendide 2100 Vented Washer-Dryer
My motor yacht's Splendide Washer Dryer combo has nerver dryed the clothes
Thor Appliances - www.thorappliances.com - and LG both have machines that can replace the Splendide.
Aug 04, 2010 | Splendide Comb-O-matic 6200 Non-Vented...
Will not dry. On the dry cycle the cloths get
check lint trap if plugged clean it maybe vent is plugged.
Dec 21, 2009 | Splendide Comb-O-matic 6200 Non-Vented...
Problems Drying Clothes
That's the way it works, kinda stupid, it would be good if it did that at first to loosen up clothes in case they're stuck to the drum but then move like a traditional dryer but that's just the way it is. BTW, here's a website with parts for it in case you need them. I never used them but just found them, I was lucky I never had any problems with my equator until now but I kinda can live with it (during rinse cycles it pumps water out but then when it does the short spins it does not, so rinsing is not as effective sinse it leaves a lot of dirty water in and then puts fresh water in and does it again, it does pump the water out during the final spin cycle though). Anyways, good luck. I bought mine in 2001 or 2002 and never had any problems except for the one I mentioned.
Apr 25, 2009 | Equator EZ 3600 CEE Front Load Washer /...
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Washer fills, drains, & final spin
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
378 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
peter gittos
peter gittos
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
