Hi,my name is Dimitar. and i have the yamaha psr 1000 keyboard. very good keyboard. but i have a problem with. when i play the rythm,allready from the keyboard,the bass is play out of tune,the other staff is okay,like: piano,strings,guytar. but just the bass is no correct play...there is example: if i play the rythm go on,and if i play on key'' F'',the bass is play on key ''C''. i buy the keyboard second hand .please help me ,becouse i need this problem resolv. thank you verry much,and thank you for your spend time,for it. if some one can help me ,please. there is y e-mail: [email protected] facebook: dimitar dimitrov
Hi
I'm not sure I completely understand your problem but......it sounds like you might be in "Fingered On Bass" mode. This means if you play a chord like F using the notes FAC- if you play them in 2nd inversion (so the order is CFA) the psr-1000 will make the note "C" the bass note. In this mode if you played ACF then "A" would be in the bass part. Change to "Fingered Chord"-this will enable you to play any chord with the tonic (the name of the chord) F whether you play FAC, ACF or CFA in the bass part. I don't have access to a psr-1000 but often with Yamaha instruments this can be changed by pressing and holding the "Auto Accompaniment" button. I hope this helps.
Musicwez
Testimonial: "Hi,there. Thank you very much,about you try to help me,i really appreciate that . i have been press and holding the "Auto Accompaniment" button..but the think stay the same agayn i play: some already rythm,and play the chords (F)-''F A C'' and everything is goin good the rythm guytars also play and follow my Chords,on (F)...but only the bass stay on the Chords ''C''...why is so wrong?????!!! :(:(:(:(:( i don't know what to do.... i'm not very good with this keyboard Yamaha psr 100.... please help me if you can . thank you .... :)"
SOURCE: Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
http://www2.yamaha.co.jp/manual/pdf/emi/english/port/PSR510E.pdf
SOURCE: Fender Jazz Bass E string saddle vibrates down
Hi Mike,
If the sound is like a string vibrating against something, ensure that is not strings (usually G) vibrating against the bridge.
Ensure that the two screw on the saddle are well in place.
Ensure also that the vibration is not coming from a string vibrating against the frets, in that case you can fix the problem by adjusting the action and rectifying the bow of the neck.
In either case, if the sadde and neck bow are cause of vibration, try tweaking the saddles a little, and lowering the position of the saddle a bit downward. Try also to rectify the neck. turning the apposite screw.
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
SOURCE: Yamaha keyboard not working
First thing is to verify the power supply voltage, including that on the board.
This can affect the threshold of the keyboard scanning and cause keys to not work although some other things appear to work.
Replacing that chip in the filed is not practical, so whole board would be considered the FRU. One can probably get one from Yamaha America parts in CA.
Before doing that, checking the scanning signals and feedback from the keys needs to be checked with a scope. Also verify that the analog power amp section is working.
