Question about Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX VR Zoom Lens
Sticky zoom ring on a Nikkor 18-55 AF-S Zoom. The zoom gets jerky at the 18-24 mark. I think it needs some lube but I don't know where to put it?
  • Brian Veall Aug 06, 2013
    When you turn the lens up side down it does not do it. Why these lenses don't come lubed is beyond me. When I use it for pictures it's not an issue. But for video it is a shot killer. This is a common problem with Nikkor lenses. There must be some way to lube them. I am using it with a Nikon D5100 Camera, and it is a manual zoom
  • Brian Veall Oct 18, 2013
    Thank you Brian. I think I will just buy another one. Thanks for your input.
    Scholar:
  • 48 Answers
You would have to disassemble the lens barrel to get to the zoom sliders, and lubrication is not likely the problem anyway. The zoom mechanism uses nylon bushings sliding in a groove, and zoom problems are usually due to wearing/cracking of those bushings.
If it's still in warranty, send it in. Otherwise, the cost of repair probably exceeds the value of the lens. Sorry.
Posted on Oct 18, 2013
4 Suggested Answers
6ya staff
SOURCE:
Brian Williams
  • 48 Answers
SOURCE: For Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor Lens
The green mark is the index for the aperture setting at 24mm, the yellow mark is the index at 50mm. These really only matter if you are setting the exposure manually and using an external meter. The green mark is the primary mark -- as you turn the ring you will notice that it lines up with a number at every clickstop, while the yellow one is a bit off.
The pull down lever you ask about is the aperture lock. Autofocus film cameras and all digital cameras expect the lens to be set at smallest aperture (highest number). They will give an FEE error if it is not set correctly. When you turn the aperture ring to smallest aperture you will be able to slide the white dot into position next to the orange mark, and that will lock the aperture ring so that it is not accidentally tgurned while using or changing the lens.
Posted on Feb 25, 2009
jf76020
  • 5 Answers
SOURCE: replacement rubber zoom band nikkor 17-55 2.8
yes...check with Nikon or I have seen replacement rings on ebay even...I'd check with nikon or a local nikon repair facility for parts..
Posted on Feb 08, 2010
  • 102366 Answers
SOURCE: On a new Nikon 18-55mm
Nikon currently lists two 18-55 AF-S DX and two 55-200 AF-S DX lenses. One in each pair has vibration reduction, the other does not. The ones with VR in the name have it, otherwise it doesn't.
VR isn't exactly an option. If it wasn't built into the lens initially, you can't add it later. A lens either has it or it doesn't, though if a lens has VR it can be switched off.
Posted on Aug 30, 2010
I have just purchased a 24-120 lens with no instructions. What is the ring with the ED for? Thanks.
You can download the manual at
http://www.nikonusa.com/pdf/manuals/lenses/AF/AFSVR24-120_3.5-5.6G_(80)04.pdf
Aug 15, 2011 | Nikon 24-120mm f/3.5-5.6G ED-IF AF-S VR...
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
May 22, 2011 | Nikon Cameras
Zoom is stuck
There is a reasonable common fault where screws internally come loose and cause the zoom to jam - you will need to get the lens serviced.
May 30, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
I need a manual for AF 35-70mm f2.8 D zoom nikkor - no idea how to use this lens.
i was not able to find a manual - this review may help http://www.kenrockwell.com/nikon/3570.htm
The lens consists of
  1. Zoom
  2. Focus
  3. Aperture
  4. Macro
1) Zoom - this is by push pull - so you push the lens out to wide angle 2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended 3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Mar 29, 2010 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Replacement rubber zoom band nikkor 17-55 2.8
Jan 25, 2010 | Nikon Zoom-Nikkor 17-55mm f/2.8G ED-IF...
Nikkor AF 18-135 lens won't retract fully
The Zoom ring maybe stuck on something, or not aligned properly Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Jun 01, 2009 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
For Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor Lens I need instruction book. Specifically, there are dots side by side marking the apeture selected, left one yellow, right one green, what one is correct and...
Feb 22, 2009 | Nikon AF 24-50mm f/3.3-4.5D Zoom-Nikkor...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Putting it back together
In 1965 I did the same thing with a Nikon single focal length lens my F Photomic. This lens was far more simple then a modern AF zoom lens. I had to bite the bullet and pay a camera repair man to fix the lens. He told me that had I not tried to fix the lens myself, the repair would have cost 1/4. The only answer to your question is to take it to a camera repair man and get a quote. I would check the quote against the price of your lens on E-bay and use that to determine if you want to fix your lens or replace it.
By the way, it is very rare for dirt between elements to be so problematic that it results in a degradation of picture quality.
Aug 05, 2008 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED AF-S DX VR Zoom Lens Logo
533 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
